I don’t think there currently is a way to rename or label plugins in a pedalboard.
That might come in handy when using the same plugin multiple times for different purposes.
Like ‘the infamous mindi’ for instance: use one for the channel selection on you amp, a second one for some external effect an so on.
Could be handy if one could label them as such.
Thanks! Had no idea that plugin existed.
Certainly looks like a viable workaround!
