Apologies if this is already answered elsewhere - I’m just getting into plugin development and have got as far as compiling my first plugin and publishing it to my Dwarf. I’ve also made some changes, rebuilt and republished the plugin successfully, but now I’d like to remove it from the Dwarf entirely. Does either mod-plugin-builder or the Dwarf itself offer a neat way to do that, or do I need to SSH into the Dwarf and delete the bundle from the lib/lv2/ directory?
You can do that from the plugin store.
Filter for “installed only” to make it easier to find. Your custom plugins will have a “local” tag.
Aha, the good old “remove it using the Remove button” trick! I thought I must be missing something obvious
Thanks!
