Hello everyone, another bugfix update for the 1.9 series is here - v1.9.2 aka “Our users are the best users”
This is a collection of fixes found by us, our users and our distributors.
Specially useful for Duo X, for which most fixes apply to.
Hope you enjoy
Here’s the full changelog:
Fix “pedalboard reset” command in device menu
Fix swapped channel 1/2 Output Volume controls
Duo X specific fixes:
Fix default bluetooth device name hardcoded as “MOD Duo”
Fix device screen boot under certain conditions
Fix integer-type parameters with % (percent) unit being wrongly displayed
Fix logarithmic-type controls over/under-shoot values when assigned to a knob
Fix toggles being assignable to endless knobs
Fix slow reaction of output volume control when changed quickly
Fix sub-optimal default codec settings
We hope you’re enjoying your MOD Duo and/or MOD Duo X.
I still have my Duo (NAND) at a lower release. When I connect it it asks me to auto update to 1.9.2. if i do this can I later switch to the new kernel? If so, how?
Never mind, I solved it myself by ignoring the message and following the kernel update / factory image installation direct to v.1.9.2
On this regard i have a question: the 1.9.2 factory image has a good lot of “built in” pedalboards and banks that I’d like to try out and investigate. unfortunately when I restored my backup from USB, everything was wiped out by my old personal pedalboards and banks.
I’d like to have both. Is there a way to “merge” pedalboards backed on a USB drive with the ones currently in the device?
