Hello everyone, a “bugfix” update for the 1.9 series is here - v1.9.1 aka “Mainline is here, so hot right now”
This is a major bug-fix release that brings mainline kernel support for the Duo.
Additionally, pedalboard snapshots can now be triggered with MIDI Program Change messages while the web GUI is open.
We have fixed a couple of bugs too, see the full changelog below for the full list.
One very important point is that for older Duo units (the “NAND” models), this update will not automatically use the new kernel.
Please check this link for more details.
And for those that missed it, we have an overview of v1.9 new features in our blog.
Hope you enjoy
Here’s the full changelog:
MOD Duo with 5.4 LTS mainline kernel
MOD Duo with mainline mtd drivers and ubifs over NAND
MOD Duo X: finalize support for rk3399-based units
MOD Duo X: set “44.1kHz de-emphasis” and “DAC invert” controls to true by default
Allow pedalboard snapshots via MIDI Program Change messages while web GUI is open
Fix buffer overflow in Control Chain lists with items bigger than 16 characters
Fix MOD Duo trigger controls doing nothing (regression in v1.9)
Fix dragging plugin out of bounds under Firefox
Fix plugin store carousel animation and positioning
Fix priority of screenshot process (could lead to xruns in some cases)
Fix wrong initial “true bypass” state in some cases
We hope you’re enjoying your MOD Duo and/or MOD Duo X.
We have fixed the issue, just pushed the actual duo update.
Those with a Duo unit that updated to 1.9.1 early, the next time you try an auto-update it will fail on the install phase.
You can manually install http://download.moddevices.com/releases/modduo/modduo-v1.9.1.1463.tar and get it all working again.
Sorry for the inconvenience!
This release is really good on CPU performance. I’m able to run pedalboards which include the JCM800 simulation and the Calf Multiband Limiter at the same time. Before, I could barely use just one of those.
Whatever changed here, seems to have optimized CPU usage in a significant way.
That said, I am experiencing various stability issues. Although, I don’t have enough experience with the release to say just yet.
I have the Kickstarter ModDuo and it was dusting somewhere since I got it. I am trying again to make a good use of it, but I have a problem updating it.
I open the GUI in my browser and I am prompted to make an update, I download it and when it starts upgrading it instantly stop and says “Download Failed”. What am I doing wrong? Didn’t find an answer searching the forums.
I guess I am still at version 1.3.2.357. That is what is in the URL of the gui
ModDuo KS, Windows 10, using a cellphone as my modem is that a problem?
Likely it is not possible to update from this version as it is too old.
You can try to manually update to v1.6 (from https://wiki.moddevices.com/wiki/Releases) and then do the auto-update
I’m a bit late in updating my mod. I have a nand one so I tried to follow the instructions at https://www.moddevices.com/blog/the-mod-duo-is-still-evolving but they do not work. Specifically, holding down left pedal button and knob while powering on does not result in MOD LEDs turning blue and a special disk appearing on my computer. Instead MOD boots normally. However, when connecting to the mod to my computer there was a prompt of a required upgrade to 1.9.1.1493 so I did that which worked fine. Tried again the hold down left buttons which booting, still no effect. Do I still need to “recreate my flash data”? Am I missing something with the hold-down-knobs-while booting trick?
I just got around to it today and I had the same problem, also with a nand one.
I got it to work by following the section at the bottom of the page - “Manual deploy from FEL”, using the command line utility on a linux machine.
It does make a difference over just installing the update from the gui. If I ssh into the mod I can see the kernel is updated to 5.4.x whereas it was 3.4.x before. It’s also shown on the settings page in the gui.
Also make sure you backup your pedalboards before you do the update. You can do that from the settings page of the gui to back up and restore using a usb stick.
After the nand update I had all the default pedalboards that I hadn’t had before and then after restoring from the backup I have both my pedalboards and the default ones.
