MOD OS 1.14 is out for the Dwarf, the Duo X and the Duo, codename “Don’t eat the yellow snow”.
It is build 3370: the same as RC6 (build 3368), built again from the same sources with only the version number and the Report a problem link changed, after six release candidates and a final test pass on all three models. If you are on RC6 you already have everything in 1.14; installing 3370 is optional.
Tone3000 inside your device. The NAM loader, the cabinet simulator and the IR loader have a “Browse tones” entry: log in to Tone3000, pick a model or an IR, and it downloads straight into the plugin. NAM plugins browse NAM models (all sizes, including A2), cabinet and IR loaders browse IRs. Brought to you by MOD Audio, made possible by our friends at Starless.
Grouped plugin controls. Plugins that declare groups show their controls grouped and colour-coded in the plugin settings.
Easy Spin programs. The File Manager has an “Easy Spin Programs” folder and the plugin’s programs are recognised. Supporting plugins will be published in the next days.
Drop and replace. Drag a plugin from the sidebar onto one on the pedalboard to swap it, keeping the connections.
Snapshots are always saved, with refreshed screenshots and a save indicator.
Report a problem button in the web interface: copies your system details, ready to paste in the forum.
Fixes, among others:
The file picker (NAM models, IRs) works with folders as deep as you like.
The web interface keeps following the device: knob, MIDI, CV and meter changes no longer stop showing after the page opens with something sending continuously. An old bug, now gone.
Text parameters (e.g. Multi Button to CV labels, comment fields) show and keep their text again.
MIDI program change switches pedalboards again after the last browser window closes.
Plus a long list of smaller ones: silent failures in snapshots, plugin installs and file transfers; pedalboard screenshots; a crash at startup in the Python bindings.
Under the hood: newer audio engine (jack2, mod-host), Control Chain master, MIDI merger, resampling and ALSA libraries.
How to update
Your device must be on 1.13.5 (if not, update to 1.13.5 first). Back up your pedalboards and files before any update; they stay in place, but a backup costs nothing.
Dwarf and Duo X: the update is offered in the web interface; follow the prompt. (registration in the servers will happen in the next hours, so the Web UI pop-up might not be triggered just yet)
You can also install it by hand, as below.
Duo: no automatic offer on the Duo; install it by hand.
By hand: download the file for your device below, then on the device go to Settings → System Upgrade. The device shows up on your computer as a USB drive; copy the .tar onto it and follow the prompt. It reboots, installs (about five minutes) and comes back on 1.14.
Can you explain Easy Spin programs? or have a wiki page that elaborates this feature?
From the name and description I don’t understand what this is/does.
I will share a plugin that uses this feature within a few days with some documentation. Essentially, it is an emulation of this programmable guitar pedal based on the FV-1 DSP from Spin Semiconductor:
And you can write your own effects for it using the Audiofab development tools and upload them to you MOD to be executed in the plugin. It’s kind of like a meta-effect. A plugin that lets you write your own effects, provided they run on the FV-1. It’s really good at modulation effects, delays and reverbs.
Maybe this is a feature rather than a bug but it surprised me, so I am trying the Report a Problem button (which appears to work well).
Paul
What happened
When updating all plugins using v1.14.0 firmware, I was presented with the message: “Could not install plugin: Plugin in use, cannot remove”. I have never seen this message before with previous firmwares - but it is also possible that I have never updated a plugin which was present in the active pedalboard before.
Opening a new, empty pedalboard and removing the default plugins, and then repeating the Update All action resulted in all plugins being updated correctly.
Steps to reproduce
Open/create a pedalboard containing a plugin for which there is an update available in the store.
Save the pedalboard
Open the Store
Click Update All
Observe the error messages: “Could not install plugin: Plugin in use, cannot remove” will be shown and the plugin(s) will not be updated
Expected
I would expect that all plugins are updated even if the active pedalboard contains instances of plugins to be updated. Since the user has the Store open, one could argue that the pedalboard could be closed during updates.
MOD release: v1.14.0.3370 (built 2026 Nov 06 07:27:55)
Device: MOD Dwarf / dwarf / aarch64-a35 / dwarf:aarch64-a35
Controller fw: 5740ab0b2023f0f8aa56fe3ee567b17f00bbd138
Kernel: 6.1.15-rt7-moddwarf
Uptime: 0h 6m
Xruns: 11 DSP load: 6.4%
Pedalboard: "Untitled" (0 plugins)
Web UI at: moddwarf.local
Browser: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:159.0) Gecko/20100101 Firefox/159.0
I´m having a odd behavior here after I´ve uploaded a file to the file manager.
Rebooting the unit and inserting the Audio File plugin again solves the problem.
I think that this is a known issue but it´s still there.
What happened**
Consecutive UI disconnections after uploading file to file manager.
Steps to reproduce
Upload a file to file manager
Refresh the pedalboard once to show the file on the Audio File Plugin
Every time that I play a file or do anything else on the PB the UI gets disconnected
Expected
After refreshing the PB once the UI should not disconnect.
I tried to reproduce it here on a Dwarf: upload a file in the File Manager, refresh, load it in the Audio File plugin, play, switch files, change loop and volume, also with a heavier board around it. The web interface stayed connected, so it is likely that something in your setup makes the difference.
A few questions to help us narrow it down:
What file did you upload: format (wav, flac, mp3…), length, size, and the exact file name? Are there special characters in the name?
Does it also happen on a new pedalboard with only the Audio File plugin in it?
After the next disconnect, before rebooting, could you send the web interface log? Connect over USB and run: ssh root@192.168.51.1 'journalctl -u mod-ui -b --no-pager' > mod-ui-log.txt and attach the file here (or send it to me in a PM).
If you can, open the browser console (F12 → Console) when it disconnects and paste any red lines.
I’ve run into a problem where the 256/128 frames setting gets reset on this firmware (1.14).
I set it to 256, but after rebooting the device, it starts up at 128. This isn’t an issue for simple presets. But in “heavy” pedalboards that can only work at 256, this is a serious problem — because when you turn the device on, it gets overloaded, and you immediately get hum and crackling at the output.
Uptime: 0h 15m
Xruns: 0 DSP load: 11.3%
Pedalboard: "Untitled" (1 plugins)
- http://moddevices.com/plugins/mod-devel/Gain2x2
Web UI at: 192.168.51.1
Browser: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:160.0) Gecko/20100101 Firefox/160.0
