did you mount the dwarf filesystem like this told in the wiki:
File system is mounted read only. If you need to remount it in Read/write mode, do the following:
mount / -o remount,rw
Hope that helps, but someone more linux-proof might chime in here.
Oh thanks I got history now !
I can write when I’m ssh in the Dwarf (I can copy files from inside with no problems) but can’t scp anything from my desktop…
Ah sorry, didn’t notice that part in the screenshot.
I remember having a similar issue, but honestly, I can’t remember how I solved it.
Have you tried to reboot the device after copying the files and then checking again the folder?
Or perhaps using a different computer?
No problem !
I’ve tried both (reboot the dwarf, connect with my desktop and laptop, both on kubuntu) with no success. Is it a problem just for me ? Did any of you tried ?
(If I’m the only one facing this I may try to find the problem in private with the support instead of the RC3 thread)
Hi @Rom just as a test, I created a /data/firmware folder (it doesn’t exist by default) on my Dwarf (running 1.11.6 2909). I copied some random file over and rebooted the dwarf. When I reconnected to the Dwarf after reboot, the firmware directory was still there, and so was the file I transferred. It sounds like there might be something up with the RC. Note that I didn’t have to remount the filesystem as read-write for this to work.
I’ve taken the time to try downgrading to 1.11.6 2909 :
I now can nano the .json files
still no way to scp from any computer
When you ssh you’re supposed to see only data and keys folders ? Aren’t we supposed to see everything ? (the USB stick for example)
I’m not sure if you are supposed to see the USB stick. Do you mean one connected to the Dwarf?
Maybe @falkTX knows what is happening when you try to scp
Is there same (1.12rc3 and latest release 1.11.6 for rollback) for MDX? Thank you in advance.
I had not updated to 1.12rc3, as I was waiting for the release version, but seems like it does not make sense anymore, and I need HMI update for looperlative hmi led feedback…
