Release 1.12.0-RC2
Hello all. This is a bugfix for the previous 1.12 release candidate.
We made some small fixes and tweaks since RC1, specially important for those that had connection issues on the previous RC.
Everyone that has 1.12-RC1 build installed, please update as soon as possible.
Those who are in “group 1” testers group will get this upgrade in their mod-ui notification panel.
Please refer to the RC1 topic to read the changes made in 1.12:
Here’s the changelog for RC2:
  • fix internal system priorities setup
  • fix modgui integer and widget rotation handling
  • update Duo and Dwarf linux kernel to 5.17.12
Duo X specific:
  • fix false trigger of button events
  • fix LED’s not turning off after potentiometer calibration mode
Dwarf specific:
  • fix HMI-Widget popups not closing properly on new events
Here are the manual download links:
Duo: https://download.moddevices.com/releases/testing/modduo-v1.12.0.2910-RC2.tar
Duo X: https://download.moddevices.com/releases/testing/modduox-v1.12.0.2911-RC2.tar
Dwarf: https://download.moddevices.com/releases/testing/moddwarf-v1.12.0.2912-RC2.tar
Hello, the manual download links don’t seem to work.
Hmmm… I was able to download all 3 just now. What error are you seeing?
Might be due to browsers not liking http links. I changed to https just now
Ok thanks, it works now.
Hi @falkTX
I’m using RC1 release.
I found a issue with my mod dwarf and mod footswitch.
I mapped plugin preset on mod footswitch, it’s more easy for me to navigate thru preset with this way.
But when editing preset or creating a new preset with the gui this doesn’t reflect in preset list on the footswitch. And then when selecting a preset on the footswitch doesn’t change anything.
I have to reload the pedalboard to see changes.
Ok.
I installed RC2 and th issue seems to have gone.
Hi, @falkTX
It seems that since OS version 1.12.0.2912-RC2 I can no longer scroll through the presets of a plugin when “Assign all” is linked to a knob, whatever the choice of “click behavior” in settings (click or direct), the list only advances by one step forward or backward.
It is the same with all the plugins and all my pedalboards. Any option to change that?
This is fixed in RC3, coming up in a few minutes!
