Hello! Now every time when DuoX starts, I have really loud digital noise. It appears when my volume is +12 on the stereo gain plugin (at 0 still present) With RC1 it was fine with these settings. And now I’m not able to roll back, my DuoX not recognizing RC1 file. Just in searching file mode forever. And CV parameter mod output sometimes not showing in the drop out menu in CV assignment, need to click a couple of times.
UPD:
Looks like on boot up system gain somehow set to maximum, even if I have +12 and then rotate +- 1 back-forward sound like +12 is much quieter than it was on the boot.
UPD2: After i re-saved DEFAULT pedalboard, this problem disappeared.
Now i somehow have fixed everything.
Thanks for reporting! And for the video! It makes it easier to see the problem.
Can you tell us the model of the tablet you are using, the software version, and the browser?
Something that went unnoticed until now.
This touch-mode navigation is not officially supported, one day we need to go through the possible actions and make it generally better…
For now I added something that makes this work again, tested in a setup similar to yours.
Coming in RC3 later today
