Hello everyone, another 1.1 bugfix update is here - v1.1.2 aka “Fix it! Fix it! Fix it!”
This bugfix is mostly for solving boot and installation issues.
With this update the MOD will completely boot even if the user data partition is unmountable.
Since 1.1.0 a quick system check is performed on the data partition as needed, and mounted read-only if problems are found. The web interface is now fixed so it can still run on this case (read-only file system).
If you have this issue, reinstalling v1.1.2 or a later update will fix it.
Next, we fixed an issue in the bootloader that prevented the main system from booting, and thus entering restore mode instead.
And finally, if an automatic update installation fails and the MOD enters restore mode again, it will keep reinstalling the OS until it boots normally again.
Hopefully with these changes the amount of install failures is reduced considerably.
For those that like the old way, here’s the download link:
http://download.moddevices.com/releases/modduo/modduo-v1.1.2.tar
And here’s the changelog:
- fix boot into restore mode after an update under certain conditions
- fix web interface to load under read-only file systems
- automatically reinstall OS if update via web interface fails
- check user data partition when installing updates (applies to future updates)
- do not fail to boot if user data partition is unmountable
(create a virtual disk on RAM for such cases)
