Here’s the download link:
http://download.moddevices.com/releases/modduo/modduo-v0.14.0.tar
Note: version 0.12.2 or higher is required to install.
Here’s the changelog:
- allow to reconfigure addressings if target is not a midi cc
- fix deletion of a plugin removing connections of others with same URI
- fix changing addressing from controller to midi cc, and vice-versa
- fix having to click twice to change addressing actuator
- fix issue in FFTW making MOD pitchshifters silent
- slightly better plugin info dialog
- show message when user tries to access banks in controller with the user interface open
- show device serial number under controller information menu
- miscellaneous fixes and system tweaks
The update procedure is explained at the bottom of the releases page,
http://moddevices.com/releases.html
