Real pedalboard and connections
I connected a pedalboard (Boss) for program changes via Trs Midi (Type A) and a pedalboard (iRig) to USB A for control changes. Everything seems to be going well, does anyone have any advice or can tell me if I’m doing something wrong?
Thank you
If everything is going well why you think you are doing something wrong?
I’m not sure if I’m using the USB A port correctly. In the past I connected several machines in cascade, via midi In, taking the signal from the midi Out and then inserting it again into the midi In of a second machine. Here the machines are both connected directly to the MOD and I hope it’s no coincidence that it works. Of course I’m happy that I have an expression pedal and 4 more control changes.
