Re-size web GUI
you know how the GUI display auto-adjusts to what you’re putting on the canvas? (if you drag something to near the edge of the canvas, the whole display auto-zooms out to fit more)
is there a way to re-set it to the original base size?
i.e. i’ve made a big, complicated pedalboard and the GUI has auto-zoomed out, but i’ve now removed a bunch of plugins (such that it would all fit in the default GUI size). it doesn’t auto-adjust BACK, but i’d like to return the display to normal sizing so things aren’t so small.
any hints?
Hello @plutek,
what happens if you zoom in on a particular plugin ( if you hover over a plugin and click), and shortly after that double click with your left mouse button on the canvas to zoom out?
Hope that helps…
thanks, marius… but no. :frowning:
as usual, one double-click on the canvas zooms out one level, and then another double click on the canvas gets back to the same, extended, full canvas as before.
Hello @plutek,
I see. I investigated more using safari on macOS.
I built a pedalboard with space for a matrix of approx 6 by 8 plugins, deleted them all and reconnected the remaining stereo gain plugin, which was a pain fiddling jacks.
I assume the canvas to be redrawn when the mod duo , in your case the mod duo X reboots.
Sorry, I am just guessing here and that my suggestion failed (without investigating on my part).
Does the button to zoom out not work for this? Or not granular enough?
hey, @mj_prod… thanks for your help… no worries! :slight_smile:
this is on my Duo, using firefox on manjaro linux. i just tried rebooting the MOD, and that didn’t work either.
oh well…
hey @unbracketed… nope, the zoom out button only zooms out to the previous auto-resized level, with lots of blank space on the canvas and smaller-sized plugins than the default.
i also just re-started the browser and cleared the cache… no effect.
cheers!
Using the latest Firefox – I still can’t zoom all the way out to see the stereo output jacks on some of my pedal boards. I’ve tried with a ModDwarf connected UI; and with the standalone UI (I assume they’re using the same web frontend) just in case – still I cannot zoom out enough to see the RIGHTHAND outputs.
I’ve tested with a blank canvas; and dropped a pedal at the very right, and was able to place it – but now I can’t scroll or zoom out enough to see it.
Anybody have this issue still?
I use Mod Dwarf with Safari/macOS. Just drag back plugins to give more space (default size of pedalboard) and switch to setting page and back. It works for me.
