EDIT:
So I got full NAM models working on the DWARF. It introduce a additional latency of 8ms at the default 128 sample/frame setting. CPU load is very low as you could see.
EDIT2// NOPE, didn’t work ![]()
That’s awesome!
You just keep pushing the boundaries. Spectacular and much appreciated, @brummer! ![]()
Awesome plugin!
But I have found a problem. Choosing a file with long name will break the UI. It was solved in neural-amp-modeler-ui repository.
Another thing is the file browser itself, it definitely wants some work. Most problematic thing is plain list, each author names captures in different way, some are without device names. I believe all users would agree: we need folders tree and some search field in dropdown menu. Then we need arrows to switch between captures within a directory. Same thing applies to all other plugins dealing with hundreds of captures or IR files. Is that possible with mod-ui?
Do you referring to the desktop version?
If so, please open a issue on the issue tracker of the github project page:
Then, please give more information about the plug version you use, were you get it from and which distribution you use.
Thank you. Submitted an issue there.
Going to report another issue, as the plugin does not save its state.
