RAM & MDA Beat Box
I was using Beat Box and I noticed that the RAM had reached 74%, I turned off the Dwarf and turned it back on and now the ram is at 18.3% why does this happen?
Was it the only loaded plugin?
Did it happen again? or was it only once?
Yes, the only plugin in use, no at the moment it is not giving more problems.
This sounds like a memory leak in the plugin.
We need to give mda plugins some attention, will add this to the list of things to check on them.
