I am looking for some guidance about quantizing events on the Dwarf.
I want to be able to use the transport control to start a sequencer immediately but want to have the stop and/or bank be quantized - such that the sequencer plays out the rest of its sequence and then stops.
I have designs on adding a looper to this setup as well; the sequencer is just playing a click for what it’s worth.
I …think… that the best way to do this may be to use CV clock to CV control in order to push the “sequencer off” button for you after a certain number of beats/measures… hopefully someone else with more CV experience will chime in on this one…
I haven’t tried using it, but there is this which looks like it can quantize up to a bar. You might be able to use it along with CV controls to turn off the sequencer at the end of the bar
