David Robillard
Fomp is an LV2 port of the MCP, VCO, FIL, and WAH plugins by Fons Adriaensen. Based on the principle of using a precomputed interpolated dirac pulse. This is the pulse variant (flat amplitude spectrum). Aliases should be below -80dB for fundamental frequencies below the sample rate / 6 (i.e. up to 8 kHz at Fsamp = 48 kHz). This frequency range includes the fundamental frequencies of all known musical instruments.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2Ryb2JpbGxhLm5ldC9wbHVnaW5zL2ZvbXAvcHVsc2VfdmNv
