“I released the first performance video with the live setup 2.o (link in bio).
I added the MOD DUO X as a controller , master processor ( using compression and eq) and reverb send.
With that i can also finally use an usb small keyboard for note input ( a keith mcmillen k board). Basically the mod duo works as a powering usb hub too ( both the faderfox and the k board get powered and go through it).
Potentially I can go further and play without mixer, very useful for small future gigs, but when you have the Model1 you need to have fun with it.
Beside that, loved this deep and chill tune, sounds only coming from the vermona and drum made with a single 808 kick sample from"
One of the Dwarf beta testers, JD, talking about his experiance with the device. This link will take you straight to the timestamp where they start to talk about the Dwarf at 11:40 (after the advertisment plays)
Thanks JD! not sure if you’re in the Forum but if you are, send me a message and I can tag you.
And thanks Guitar Nerds!
@shaggydog
“This is me with a Dwarf which has a sequencer for the drums, an Alo looper (beta) for the loops and a couple of reverbs, a delay and a wah on the bass/guitar”
