I am facing an odd issue and need some advice pointing me into the right direction.
MVP setup to reproduce the behavior:
Dwarf via USB to Macbook. Macbook has two network interfaces: Wifi and the Dwarf. Accessing the web GUI of the dwarf and the internet simultaneously works perfectly.
Directly after unplugging the dwarf the internet connection is gone.
What I noticed:
It is not just my computer. It affects all devices on the network.
I assume that my router somehow recognizes the dwarf as the main DNS and cannot resolve anymore when the dwarf is gone. Only restarting the router helps. I tried setting a static DNS (Cloudflare) in the router, but that didn’t help.
Any suggestions?
You can image the reaction of my family when every time I play guitar the internet is gone afterwards
I am not an expert but I assumed that (if it is really DNS related) changing the DNS from “Auto” to a static one should have helped… but unfortunately not.
BUT:
I logged onto the Dwarf to check avahi and dnsmasq configs (seems to be as it should be - but I have limited knowledge) I noticed that when I gracefully shutdown the Dwarf using “poweroff” from the ssh session Internet connectivity stays intact.
That is ok for me for now - I just have to remember to not just pull the plug^^
