Hello everyone and happy to be part of your community.
I’m posting this in response to myself about an issue I wanted to submit :
“Hello, I purchased a “MOD DWARF” and am desperately trying to access the web interface via USB on a mounted Hackintosh Catalina dual boot with Windows 10.
No problem on Windows, where I can do all the creations/manipulations. The problem is that I have Ableton Live installed on the Hackintosh, and going back and forth between the two systems is a pain. The “DUO ethernet” interface does not appear in the network configuration although I have “MOD Dwarf” which is displayed in the USB tree of the system information.
Does anyone have a clue regarding this problem under Hackintosh? Maybe a kext exists for the interface used in the Dwarf, but nothing appears regarding the chipset used.
Thanks in advance.”
I finally found on this page https://github.com/jwise/HoRNDIS/issues/102 and if it can help someone, you have to download and install this kext: https://github.com/jwise/HoRNDIS/files/3719733/HoRNDIS-9.2-catalina_install.pkg.zip and the “DUO ethernet” interface will appear.
Hoping this will help
