This pedalboard it to demonstrate using midi notes to toggle effects. Each midi note in C scale from the C above middle C up to B will toggle a different effect (using the HW midi loop cable). You currently must send a low velocity note (quiet one) to turn the effect back off.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/58c0ecf02564d438cbc1a466
