What are the power requirements for this device? How many volts and mA?
We provide the power adapter when you buy a mod duo. Its spec is 12V, 2A.
Isn’t it a bit less than 2A ? I ask, because even 1/4 would make a big difference for those who want to use only one power supply
Thanks !
It surely will work with 1.5A power supply, however we do not recommend to use a power supply other than the one we provided. In the future when you plug a control chain device to your mod it will drain more current and will require a better power supply.
Ok ! It’s good to know ! Thanks
I wish that the mod case would have “2A” next to the power connector input. It is standard practice to write all power requirements on the case.
