I am wondering if there is a plugin that will send out MIDI Program Change messages.
The reason I’m asking is because I have a Digitech Whammy DT and want to have it change settings with a push of a button. Currently I have to bend down and turn the knobs to the settings whenever I want to change them. I have different settings for different songs. The Whammy DT (and Whammy Gen 5) has Midi input and you can control everything on the unit with MIDI.
Another creative thing is to be able to change a MIDI note to a MIDI Program Change. You can use the sequencer to change the settings on the Whammy and have some really crazy beat based pitch shifting effects. A company that makes something like this is Molten Voltage called the G-quencer http://moltenvoltage.com/products/G-Quencer_-Revolutionary_DigiTech_Whammy_Controller-_by_Molten_Voltage.html
With the upcoming 1.3 update there can be sooo much great stuff we can do and streamline the live playing experience with the “scenes”… I can’t wait!
I know there is already a whammy plugin but I just don’t have enough CPU for what I want. However, if these plugins are around or available, the DUO would be the same price as having a Whammy DT ($300) with a G-quencer ($350)…
I had not actually thought deeper about the matter but you’re right
According to @Skydiver original post , there would are actually two possibilities:
1 - in the midi filter package, following the midi-in/midi-out standard, we would have “MIDI-CC to MIDI-PGM” or a “MIDI-Note to MIDI-PGM” plugins, just like the existing MIDI CC-to-Note and MIDI Note-to-CC ones
2 - another option is the out-of-standard ControlPort-to-MIDI-PGM
MIDI-CC to MIDI-PGM is tricky. CC are 3 byte: key + value pair. programs-select are 2 byte (single program) optionally prefixed by a bank-select message.
The MIDI-filters all use standard control ports which are automatable (can change any time, the filters adjust and prevent getting stuck notes etc).
For fancy cases like CC to PGM a fixed - not automatiable and rule-based config is appropriate. That’s what https://github.com/x42/midimap.lv2/ does; but midimap.lv2 depends on a config file (containing the rules) and is hence not available on the MOD. A workaround until the MOD allows a user to select files would be to ship a few presets.
Still it’s probably overkill and a small dedicated plugin for the issue at hand would be more practical on the MOD. YMMV.
Very interesting… I always learn more than I expect from things I post… HA!
I think there will be people who will want to control outboard midi gear from their Duo.
For this specific case, I want to be able to pull up a pedalboard for a song, or a scene for a part of a song, and have my Whammy DT set to the settings that I need. I saw this video for Steve Vai’s rig and he shows that his Whammy is connected via Midi to the Fractal. https://youtu.be/90HmdenswGM?t=28s
Would it be hard to create a plugin that sends out a specific Program Change message? Maybe be able to scroll through different program messages. When I bring up a pedalboard I would want it to send out the message without having to hit a button… same for any “scenes” I scroll through…
Creating a plugin that sends pgm-changes (or any midi sequence) is easy.
Making that plugin configurable is the hard part. – and making it look cool (no boring textarea) even harder
How about starting simple: 2 knobs to define programs (0…127) and a push-button. Every time you press the button a midi-pgm message is sent alternating between the two selected programs.
It could also be 4 or 8 steps, and maybe another control to select the MIDI-channel…
I’d definitely keep the textbox in the plugin config dialog if possible, not on the plugin UI on the pedalboard. It will look much better that way IMO.
Another approach would just be to send the pgm-change whenever the port changes so just have 1 input port with range (-1,127). That way when it loads the pedalboard and the host sets the port value it will send. Wouldn’t be very good in many cases but would work for Skydiver’s specific request of buttonless PCs.
