Hello,
Do you know any plugin that outputs MIDI transport/clock, for me to use as input for Gen plugins ?
I only found plugins that output pitch/gate.
Thanks
As we speak I’m actually working on a (testing) plugin in pd/hvcc (the opensource counter to Gen) that takes transport information and outputs MIDI clock (and start/stop messages), however this is all done inside the DPF wrapper.
Probably the DPF wrapper for Gen could introduce a similar mechanism where it responds to transport controls that are then available inside of Gen?
thanks for your answer, unfortunately my programming skill stops at Gen for now… a plugin like “MIDI to CV” with transport would be easier but I keep learning.
Actually, I totally forgot about MIDI Clock Generator - MOD Devices
Set this to Host Sync and you get midi clock out.
