I did not look for posts on this topic. If this topic is already being discussed somewhere on the forum, I do apologize for the redundancy.
Does anyone know if it is possible to change pedalboards using a footswitch MIDI controller, has anyone tried to find a solution for this on Mod Duo X? For example, if a pedalboard is too complex and consumes CPU then a possible solution would be to divide it into two pedalboards … but then there is a need to switch between the two pedalboards through a footswitch solution. I’m not very good at programming and MIDI settings and I don’t really know what solution to think of to solve this problem Thank you.
Yes. That is possible. Take a look here
Thanx a lot, Jon🙏
