Wihch is your favourite WAH plugin to use in a classick rock (Zeppelin, Hendrix, …) which can be controlled by an expression pedal?
I have tried some of them and none impressed me, but it may be due to the cheap pedal I am using…
I haven’t experimented with that but doesn’t it have to do with the sweep ranges?
As you can see here, each wah has its own frequency range
https://www.sweetwater.com/feature/dunlop/wah-pedals/index.php
As you can see here, several of the “wah” plugins have parameters to manipulate that range.
I haven’t tried using an expression pedal myself but if you try to explain which aspects are a problem, perhaps the community here can help finding a good setup for you?
