Anybody have a compressor in the works with a clean blend feature? I dig the compressor I’m using in the Mod Duo right now but normally with hardware units I prefer to blend in some clean signal for definition. Thanks!
I’d say split the input, one going to the compressor, the other to a gain utility to blend in the dry signal.
You also could use the Stereo X-fade.
Both good ideas. I’m bumping up against the CPU meter right now but I will give it a try, thanks.
