Onyx Presets Switching / Get rid of Factory Presets
I think you mean select “save” and then select “snapshot”
That will save the current active snapshot or all of them?
oops, in the time it took me to walk from my dwarf to this computer, my brain swapped “pedalboard” and “snapshot”
As far as I can tell it saves the current state only, in a new snapshot.
Ok thanks for answering that one!
Can you overwrite excisting snapshots? Seems you can only save the current snapshot into a new one…
I believe it only saves new snapshots. I think the use case is that you save a new one during a performance/sound check, and then go back and edit the new one in the web UI.
Yes. You still need to save the pedalboard otherwise the change will be lost (as it happens if you don’t save the pedalboard after saving the snapshot on the WebGUI)
If I don’t mistake, you can. You only need to use the same name and you will be asked if you want to overwrite.
