If by “exclude devices” you mean exclude a plugin like having a Distortion in one snapshot an not having this same Distortion in another, then it’s not.
But you have ways to bypass it or simply have it “on” in one snapshot and “off” in another.
Ok thanks, that is what I meant. Then this feature is not really useful for that case, cause I only want to switch around my Drive/Amp section, leaving the rest of the chain unaffected.
Snapshots do just what they say . It’s a snapshot or picture of what’s happening at that point. If you don’t change other parameters / fx then they will stay as you set them regardless of how many snapshots you use.
So just an example: I make my 3 snapshots for clean drive etc.
Then during soundcheck I use the EQ to scoop out some frequencies that cause Feedback on the Piezo chain.
What I would need to do then is ajdust this in each snapshot, again and again and again.
Regardless to say that I don’t even know if you can overwrite snapshots on the hardware.
I have to say though that I’m also not 100% with the presets solution, cause it has the same problem.
I do soundcheck and I wanna tweak the EQ of my Drive preset. It seems I cannot save these changes on the hardware
Ah OK. How about just mapping the EQ section to the knobs that way you can adjust regardless of snapshot. Or set up a Midi controller to do same. Did something similar with TouchOSC so I could adjust standing up and listening
Yeah but then loading a snapshot will overwrite these manually adjusted changes.
It would be great if you could exclude devices from a snapshot. A lot of digital hardware soundprocessors have like a global section.
My TC Helicon devices for example have the tone section global, so I have EQ, Compression, Deesing independant of presets. So they can be adjusted during soundcheck and don’t interfere with the rest of the preset.
Nevertheless I settled down on using 2 footswitches for cycling thorugh the presets. That way I can more easily ignore the factory presets at the end.
EDIT: I’m still eager to know: Can you save snapshots on the hardware without the editor?
Ok. I get it!
I have the same concern as you but it does not affect me so much because I usually have only 2 snapshots on pedalboards an I use an extra EQ plugin at the end of the chain and map it to knobs for quick on the fly changes
This should be a feature request but I don’t know how things gonna be handled due to the insolvence.
Something like “Set plugin as global”. When a plugin is marked as global, saving the pedalboard should save the current settings of these particular plugin to all snapshots.
It probably have been requested already. @redcloud have you requested this?
since no one seems to be answering this question, yes! You can save a snapshot from the hardware. Hit the menu button (on the dwarf, this is the button on the far left above the foot switches), select “save” and then select “pedalboard”
I believe it only saves new snapshots. I think the use case is that you save a new one during a performance/sound check, and then go back and edit the new one in the web UI.
Yes. You still need to save the pedalboard otherwise the change will be lost (as it happens if you don’t save the pedalboard after saving the snapshot on the WebGUI)
If I don’t mistake, you can. You only need to use the same name and you will be asked if you want to overwrite.
