One kernel version for all devices
I have one more request: I’d like the Duox to have the same kernel version as the Dwarf and Duo - in other words, one kernel version for all existing devices.
If you want this kind of work done by the small mod team, I think you’ll have tout explain why, don’t you ?
  • A newer kernel version supports more Wi-Fi models, among other things, and is more up-to-date.
  • Starting with kernel version 6.12, RT is included in the official kernel.
  • Starting with kernel version 6.5, MIDI-2.0 is included in the official kernel.
  • It is easier to maintain a kernel version and to create and maintain the operating system and plugins for it.
You asked for same kernel for all mod devices, now you ask for newer kernel.
What is the purpose of having the same kernel for all devices ?
The problem is that DuoX has two separate device versions and requires a lot of highly specific patches applied.
It is very non-trivial to port this to a different kernel.
The term “newer” kernel refers to the fact that the DuoX uses an older kernel than the Dwarf/Duo.
So, to be precise: All devices should use the same kernel - ideally, the one from the Dwarf/Duo.
The main advantages:
If possible, that would be great; you’re in a better position to evaluate the technical aspects.
All I remember is that falkTX was quite hesitant to do this.
Ideally patches get pushed upstream as much as possible of course. Then there is less burned to maintain a fork/patch-set.
