Hello, I don’t know if this is the right category, and also apologies if the terminology is not the right one.
By sideloading I mean, when I have an LV2 plugin that I want to deploy to my mod DUO directly via USB (ie bypassing the usual modduo.local webinterface and downloading from the official store). I could want to do this for many reasons, mainly: the plugin has not been released to the official store, or if I am myself developing a plugin and want to test it.
Now, the wiki states that:
You can push an LV2 plugin bundle to a MOD unit via command-line, using curl, by running this: (adjust as needed)
$ cd ~/mod-plugin-builder/plugins/package/eg-amp-lv2/source/
$ tar cz eg-amp.lv2 | base64 | curl -F 'package=@-' http://192.168.51.1/sdk/install
…But on the other hand, someone in another thread, developer of OR - Expression Ramper, stated that we can:
ssh into the mod device by connecting to 192.168.51.1
use credentials "root" and "mod"
then copy the plugin to the folder /root/.lv2/
Now, these are similar but radically different ways; first one, from the wiki, is compressing and encoding the plugin, then copying to a /sdk/install/ folder; the second one seems to be the option to deploy plugin files directly to the .lvs folder where plugins actually live.
Could someone please clarify if these options are equivalent, which one is best, and under which conditions?
Also, just to clarify, I have a mod DUO in case it makes a difference.
Thanks in advance!
