Before I sold half of my gear to switch to Dwarf I liked having clean sounds and combine wha > octaver > chorus.
On the dwarf I didn’t find any viable solution for replacing my sub’n’up (+1 oct, -1 oct, -2 oct) because:
- GxOC-2 is sounding ok, but I finally spotted it as the guilty sound storms generator that sometimes happens, which are absolutely not tolerable on live conditions. Huge issue. (already mentionned on the forum).
- MOD 2Voices is close to what I like but damn it is CPU expensive. Having 1 of those with a few other pedals and the pedalboard runs at 70% even on Medium tracking…
- Pretty much the same for the pitch shifter MOD Drop with only -1 octave.
From what I learned on other posts this is pretty much it: pitch detection is expensive. End of the story ?
So unless I’ve missed something, my question would be more: do you suggest something else in replacement ?
Having an octaver makes the signal stronger, wider. I use it to raise intensity in solos while keeping the signal clean (I play mostly jazz). What else could I try ?
Thanks in advance for your advices !
Nicolas
