Sounds very good, maybe can be used to reduce noise from hi-gain amps?
I’m afraid spectral noise reduction plugins introduce a lot of latency. They’re usually employed for post-processing.
The GitHub page says “[t]he plug-in will introduce latency so it’s not appropriate to be used while recording (35 ms for 44.1 kHz).”
Yep, maybe it could be used lowering the quality while keeping the latency acceptable.
