New Tape Emulation on the block
Centaur works great on the DuoX with the modduox-static build! get about 10-15% cpu and very nice gritty distortions from deep fuzz to screeching highs.
AnalogTape seems particularly heavy on the oversampling. Reducing that helps a lot on the cpu usage. Typically the 8x/16x oversampling would never be used.
Maybe simply patch the parameters to not allow these, and modify or remove the offending presets?
I cannot for the life of me get it to build. Any chance someone can dm me the centaur build for modduo?
it needs to be the new modduo-static. so basically:
cd mod-plugin-builder
git pull && git submodule update
./bootstrap.sh modduo-static
./build modduo-static chow-centaur
./build modduo-static chow-centaur-publish
But I can upload a premade build sure.
https://falktx.com/data/ChowCentaur.lv2-duo.tar.gz
Thanks @falkTX
I get a forbidden when I go to that link…
sorry, fixed now
Amazing! @falkTX you are awesome!!
@chowdsp @falkTX the ChowCentaur is mad good! Very smooth and no artefacts at all! I get about 15-20% cpu usage on a pi3A+ running armv7. Would I benefit at all from a 64bit os?
Did you manage to finally build it? I have exactly the same error…
Thanks!
regards Fer
When did you try to build this?
It should work fine with the latest MPB stuff.
just now, but with an old docker image (although I did a git pull & submodule init and update and bootstrap again)…
I would love to have Chow Centaur on my dwarf, but am completely new to programming. Can anyone help with specific instructions?
Thanks in advance
we will try to push it officially, so if you are patient, it will appear in the store eventually.
I can also push it as beta, though we need a small update in the cloud infrastructure first.
I can be patient. But would also be cool to know how to do it in case I find something else I would like to use.
I’m trying to upload to my dwarf using docker and the mod sdk, however the instructions on the wiki give an incorrect command prompt. Here is what I am getting.
C:\Users\derek>docker run -p 9000:9000 -v C:\Users\derek\Desktop\LV2 Plugins:/lv2 moddevices/modsdk
docker: invalid reference format.
See ‘docker run --help’.
Once again new to coding, can you help?
mod-sdk? I think you mean mod-plugin-builder
Assuming you are looking at How To Use Docker Toolbox With MPB - MOD Wiki ?
Were you just looking on the wrong place as @dreamer suggested or you confirm the issue?
TBH I don’t know enough about coding to even be attempting this. I’ll just have to wait until it is pushed through as beta
Let’s hope that it’s soon :wink:
Any news on this plugin being available soon?
Thank you
There needs to be a modgui (html/css) interface made and maybe patch the source-code to disable the heavier oversampling modes (it’s unusable with those).
