So I’m working on a patch where I use a CV based sequencer being transposed by another MOD sequencer.
I love the process, as it is definitely working the way I want.
That being said…
Is there a more convenient option?
Any plans for a sequencer that just allows me to assign pitch, octave, gate, and velocity, in an environment that doesn’t require midi values?
I’d love a sequencer that gives me those basic parameters and not having to do math for 127 values based on note+octave.
For example, I don’t know what value 62 is giving me. If it’s an A note in octave 4 then just let me choose the note from my scale, and an octave. A4 is a great way to present that rather than midi value.
I was just looking for the midi sequencer with the data presented differently. I still very shaky on my scales, so seeing a note name rather than a number would be pretty helpful. Even a scale and numbers would make more sense to me than midi values.
I’ll watch that video to see if I can speed up the process, but I own several hardware sequencers that will do what I want. I am hoping to use the MDX as the transposition sequencer and save another power cable haha
I need to dig into the sequencer a bit more and see if it can do polyrhythm stuff or not.
I think I made a request for a CV quantizer as a separate thing for my analogue sequencer.
Ok. Thanks for the clearance. So simply notes instead of MIDI values?
No velocity or so? Can I bump in your request to add the velocity request and also be able to select what message type are we sequencing? haha
@Elk_wrath, first of all thanks…I can’t really add any feature…
Actually @khz touched an interesting point here.
I don’t know if I’m imagining something, but I remember @falkTX asking somewhere here if some of you were interested on getting some Cardinal modules ported for the MOD. @falkTX now you can kill me if I’m just imagine this
Here you have an overview of all modules in Cardinal.
However, you have to search manually for the modules / documentation on the Internet.
This directly in the mod device / Cardinal retrievable would be very good.
Actually all ~943 modules would be good if they were directly usable on the mod device.
As far as I know, there are some overlaps. Almost 1000 modules may also be quite some work, but I guess that with a good enough priority list, @falkTX may be able to slowly push some stuff.
Maybe create a wrapper for the Cardinal modules, that enables the GUI of the module and its available inputs and outputs to be seen
People can choose the modules themselves saving porting 1000 over.
I know the MOD cardinal is sort of a wrapper but it’s a very clunky operation at present - although better than none what so ever.
Or maybe Falktx can show what is needed to fit the MOD structure and let the forum take care of it - appreciate I’m making that sound a lot easier than I’m sure it is.
I haven’t had a need for a computer since college, and it appears that the devices I do own don’t have access to the internet due to hardware failures.
Sadly, the iPad isn’t exactly useful as a laptop in terms of features. Has great apps, but I can’t install any actual programs.
