New Plugin - Toby the Cat
ABotte Sounds is delighted to introduce the most purr-fect, cat-a-licious, adorable plugin not only within the MOD Ecosystem, but across the entire music industry: meet Toby the Cat
It couldn’t have been anything other than a distortion pedal: one switch flips your signal from purring overdrive to clawing, hissing fuzz.
Forget everything you know about germanium or silicon transistors, throw away your clipping diodes: this pedal was meticulously modeled by closely observing actual feline behavior! Meow!!!
Toby sits proudly in your signal chain, eats a good chunk of your CPU and refuses to apologize—because looking awesome requires system resources.
Packed with a few Easter eggs (let me know when you find them :slight_smile: ) to enjoy having a cat in the screen, reigning supreme over your pedalboard.
Grab some band-aids and a good supply of cat treats, and adopt your cat here: MOD Cloud Builder
@Abotte this is the way. My CPU is terrified, but I am thrilled to try it!
PS I had a “nails on chalkboard” based distortion idea in the works as well, but as you might guess it was not very pleasant! :joy:
@Abotte awesome plugin, right from the start very nice sound. Using it with my dwarf !
