Hey,
The Chance knob controls the probability for a new auto trigger to activate a stutter yes or no. So it’s only for when Auto is turned on. Duration controls how long (also random) that stutter then repeats in Auto mode before the next trigger.
When all note lengths are set to zero it defaults to quarter notes. I haven’t really thought about it that long. Maybe it’s more intuitive if it defaults to no stutters at all. What do you think? Fyi: the note length probabilities are normalised, so that all note probabilities will sum to 100%.
I think it would be more intuitive if there were no stutters when all note probabilities are set to zero.
When I first started using the plug-in, I incorrectly thought that each note length had a volume control. I didn’t understand them as individual note probabilities.
I always use auto mode, so far.
So I’m still unclear on how this works. If chance is set to 100%, and 8th notes is .5 and 16ths is .5, what is the result? There is a 100% something will happen, but only a 50% it will be an 8th note, and 50% it will be a 16th note? Could there be zero glitches with chance set to 100%? Or if neither the 8th, nor 16th trigger, does it always default to the quarter note even though that was set to zero?
Possibly in auto mode you only need the chance settings for each note length, and not the top level chance setting? Or I’m still misunderstanding how they relate to each other.
I understand this can be a bit hard to grasp . So I’ll try to thoroughly explain how this Auto trigger mode works.
A random note length is always chosen based on the slider values. It holds for a randomly chosen Duration before the next trigger. Chance controls the probability of the stutter to be heard or not. For the note length selection; if you have 4th set to 50%, 8th to 50% and 16th to 100% and the other sliders to 0%. Then it effectively results in 4th set to 25%, 8th to 25% and 16th to 50%. So it’s normalized to sum to 100%. To me it helps to think of the sliders just as visual indicators. If one slider is higher than the other, it’s that much more likely that note length will be chosen. It’s relative, not absolute.
That’s why everything set to 0% is a bit of a special case. You can’t really normalize that. I’ll make it default to no stutters in that case. It makes more sense to me too!
To answer your specific questions for clarity. With Chance set to 100% and 8th and 16th to 50% a trigger should always occur. And the trigger will always be an 8th or 16th. In this case an equal chance. I hope that clears things up.
In the end I decided to add a Mix parameter instead of a Dry Thru switch. With the Mix parameter you can set the mix mode to:
Dry or Wet
Dry & Wet
Wet only
Hopefully it’s clear what the difference is between these.
Do any of you now feel the need to control the wet and possibly the dry level?? This is of course already possible by using the “Wet only” mix mode and a separate Gain plugin. But if there’s high demand for level control I could add it natively. If not, I’d rather keep as few controls as possible.
This version also has a fix for when all the note probabilities are set to 0%. This will result in an equal chance for all note lengths now. @S_Righteous We discussed it would make sense to have no stutters at all instead. It proved to be hard to implement. And when implementing it felt unintuitive to have a non-responsive plugin too. That’s why I ended up using an even distribution for this edge case instead.
An even distribution also makes sense to me, but it’s just an edge case that someone would want that. Having all sliders set to any ‘same value’ would do the same thing - it’s consistent that way. Right - if all sliders are set to 50%, then they are all equally probable. So having them all probable at zero is the same.
But if any of them are set to non-zero, I assume all the zero ones will never happen right? Or at least that is how it works now.
back on this thread after a long hiatus. I noticed that when I set the on/off switch to be controlled by the device using a knob, it doesn’t work. With the plug-in open, I can see the block switch from off to on, and back again - but this does not affect the signal. The ON button on the GUI works, when it’s lit, the signal gets stuttered, when it’s off the signal passes through. But something is weird when using a knob to turn this on/off. I can te-test tomorrow to see if it works with CV.
I’ve figured out what is going on. The ON/OFF button in the graphic interface isn’t connected to the ON/OFF button you can toggle in the settings.
So if you have the button on the GUI off, you can set a knob, CV, or whatever to control the ON/OFF state from the settings, and you will see that get toggled in the settings, but it will do nothing. The red light in the GUI will not turn on with that toggle.
If the ON/OFF button is on, the GUI will show the red light. Now the toggle in the settings will work with whatever you have set up to toggle it. It works, but it just does’t display differently in the GUI. A bit unintuitive, but workable.
Ah, I see. Look for the ON instead of the ON/OFF switch if you go to the settings. That controls the same ON toggle as the one in the GUI. The ON/OFF in the settings is just for turning the whole effect on or off. It’s provided for every plugin on the MOD automatically.
Thanks @DaveM !!! It took me so long to take the time to test this plugin but I’m quite impressed and happy with it !!!
Do you think it would be possible to have a CV output that send an impulse each time a loop is repeated ?
I’d like to use this CV to change the panoramic and send in re reverb in sync with it.
Hi @DaveM
Thank you so much !
Do you think the CV output can send a pulse each time there is a repetition in the stutter ?
I was hopping to put each repeat in a different position in the stereo. I have made a pedalboard but I can’t upload in the pedalboard library (I think because I use the Starless modOS)
Here is a pedalboard made a year ago with just the panning thing :
If you replace the CV Clock with the output of the dm-Stutter you should have the same pedalboard that I would have shared.
@RomHere’s a new build with CV triggers for every repeat. There are two CV outputs now. One called “Trigger CV Output” and the other called “Repeat Trigger CV Output”. That’s the one you want.
Oh, this is cool !!! Thanks a Lot !
In this build the Repeat Trigger CV Output is sending a pulse even when the *on is not pressed. Do you think it could stop when the swhitch on is released ?
I could live without though, this is already really great !!!
