New plugin: dm-Reverb
This reverb plugin is inspired by the Make Noise Erbe-Verb. It’s in BETA now!
You can go from extremely small to large spaces by changing the Size knob. Reverse will turn the Predelay into a reversed predelay, which is especially noticeable on percussive sounds. Speed and Depth control modulation. Turning Depth below center will modulate the space size with sine waves, turning it above center will modulate the space using granular synthesis. First third of the Absorb knob controls the diffusion and the last two thirds controls the dampening. Tilt controls a shelving filter which affects the tone of the reverb dramatically. Below center it will emphasize lower frequencies, above center it will emphasize higher frequency. Shimmer will add higher octaves to the original input signal. And turning the Decay above 100% will make this reverb self-oscillate! The increase in gain when you go in self-oscillation is controlled to a large extent. But when it goes crazy you might want to add limiting or some other volume control.
Very nice, easy to use, and low CPU consumption reverb !
thanks a lot
Thanks, Rom! I tried to keep it as light as possible. It’s good to hear a user’s perspective on this.
It might be good to know that changing the Shimmer and Depth controls to above zero will make it use a little more cpu.
Very pleasant, very useful, very nice plugin! Thank you!
