New NHE Plugin - Temporal Rift - Microloop sustainer
The rift has opened.
A sustain pedal for any instrument, for MOD Duo, Duo X and Dwarf
Press, and the moment you just played stays. Not a loop, not a freeze that stutters: a living hold that breathes like a piano’s sustain pedal, for a guitar, a voice, a synth, anything you plug in. Lift your foot and it fades away. Press on a new note and the new one takes over while the old one dissolves underneath.
A tempo-synced tremolo chops, pulses and pans the held sound, and a Burst function kicks it off fast and lets it ease into the groove every time you press.
Demo video of a number of presets
Why it sounds like nothing else
  • It waits Set sample lag to suit your playing. On the note, or a second behind, you decide.
  • No seams. The held sound is woven and matched to the waveform so they add up instead of cancelling. One clean tone for a note, a steady chord for a chord.
  • Layers, not cut-offs. Every press starts a new layer while the last one fades on its own time.
  • Your dry signal is untouched. The tremolo, the width and the swell all live on the held sound only.
  • A real half-pedal. Put a MIDI sustain pedal on Damper and part-way down holds quieter and muffled, like the felt on a piano string.
  • Advanced tremolo bpm sync, wave shapes, intervals, and a burst function that starts fast and drops into your tempo over time. Your sustained sound can sound like anything!
How to play it
  • Hold: assign it to a footswitch (momentary by default). Press a moment after you pick, and that sound stays. Lift and it fades over Decay.
  • Clear: If using a latching switch, assign it to a second switch or to MIDI. Drops everything.
  • Damper: MIDI-learn it to your sustain pedal (CC64). Above 10 % it holds like Hold; part-way
    down is quieter and darker, all the way down is full. Hold overrides it.
  • Sample Lag (0–1000 ms): grab later than your attack, let a chord bloom before it’s held. Press on the beat, and the grab can be delayed to what you set.
(Hold, Clear, Damper and Sample Lag live in the plugin’s settings and on your footswitches, not on the face.)
Controls
Voicing
  • Voicing controls grain size. Granular (120 ms), Cellular
    (200 ms, the default), Atomic (400 ms) and Nuclear (600 ms).
  • Warble: off is a clean, steady hold. On, the grains start anywhere and the hold shimmers
    and smears.
Envelope
  • Rise: how long the held sound takes to swell in, 5 ms to 5 s.
  • Sustain: where it settles once Rise is done. 100 stays full. Lower eases it down over about two seconds and darkens it on the way, to −15 dB at 50 and −30 dB at 0. It never fades out while you hold.
  • Decay: the fade after you let go, 10 ms to 10 s. Turned all the way up it reads HOLD and rings until Clear.
Tremolo
On the held sound only. It restarts on every press, so press on the beat and it lands on the beat.
  • Depth: 0 is off, 100 is maximum chop.
  • Rate: the tempo in BPM, 20 to 300. Type the song’s tempo; higher is faster.
  • Sync: Rate follows the pedalboard tempo instead, tap tempo included. The Rate readout says SYNC.
  • Divide: cycles per beat, from 1/1 to 1/32, triplets included.
  • Shape: sine, square, rising saw or falling saw. Hard edges are softened just enough not to tick.
Burst
  • Burst: each time the held sound starts, the tremolo starts fast and eases back to Rate. Works with any Shape.
  • Rate: how fast it starts: quarters (×4), triplets (×3) or sixteenths (×16).
  • Burst Time: how long it takes to settle, 50 ms to 5 s. It stays fast at first, then eases in.
Mix
  • Blend: dry and held sound both full at 50; held sound only at 100.
  • Width: spreads the held sound across left and right. 0 is mono.
  • Pan: the tremolo’s left and right alternate, so it becomes an auto-pan. The mono sum stays level.
  • Tails (in the settings): bypass lets the held sound ring out.
Presets
Fourteen presets, all have Sync on (80 BPM when the pedalboard has no tempo), Sample Lag 400 ms, Rise 300 ms, Sustain 100, Decay 5 s and Burst on, unless the last column says otherwise. Loading one never grabs or drops a held sound, and never moves Blend.
Preset Voice Tremolo Also
Hammertone Cellular, Warble 100 % falling saw at 1/16T, bursts ×4 over 1.0 s –
Harmonica Cellular, Warble 56 % rising saw at 1/2, bursts ×16 over 2.6 s –
Maximum rise Cellular, Warble 42 % rising saw at 1/4, bursts ×16 over 5.0 s –
Reversing into the rift Nuclear 100 % rising saw at 1/8, bursts ×16 over 2.6 s –
Saviour Atomic 100 % sine at 1/8T, bursts ×16 over 1.3 s Width 76
Slow down Atomic 52 % sine at 1/2, bursts ×3 over 2.6 s –
Smooth pad Nuclear none –
Ultrasmooth Nuclear none Sample Lag 500 ms
Chopper Cellular, Warble 100 % square at 1/16, bursts ×3 over 2.6 s Width 100
Clavichords Cellular, Warble 63 % falling saw at 1/32, bursts ×16 over 139 ms Width 100
Organ Nuclear 34 % sine at 1/16, bursts ×3 over 139 ms Width 100, Auto Pan
Choir Atomic, Warble 29 % sine at 1/32, bursts ×3 over 139 ms Width 100, Auto Pan
Vocal Nuclear 26 % sine at 1/32, bursts ×16 over 139 ms Width 100, Auto Pan
Glitch Granular 23 % square at 1/2, bursts ×16 over 139 ms Sample Lag 0 ms, Width 100
Outputs
Mono in. Mix L/R carry dry + held sound; Wet L/R carry the held sound only, whatever Blend says, for putting effects on the sustain alone.
Install
Cloudbuilder install (Version 1.0.15)
Happy playing!
Stunning interface (as always)!
I loved the first two parts of the demo: it took me directly into Kill Bill Volume 2 :slightly_smiling_face:
Hope to have the time to play with it a little bit this evening!
Thanks!
I might add a switch to tame the rift animation (slightly worried it might induce seizures at some settings :grimacing:)
Anyway, a pleasure as always. It’s had quite some refinements and I think this effects has been really changing my playing. It’s a whole new world!
I think you’ve done it again and I’m going to end up switching out Galactic with CV freezing for this plugin! Your stuff has inspired a bunch of pedalboard tweaks for me :slight_smile: Thanks as usual.
:eyes: this months cookbook challenge might have something you like then… :melting_face:
Awesome! btw, just spent some time with this one, I think it sounds great but it just stopped working a few times on my Duo X. I’ll see if I can figure out what triggered it to go out :slight_smile: – it may end up that I just need a restart and it will take care of itself. More testing tomorrow…
Yeah, let me know. As in triggered sound stopped? (lost the latch) or plugin stopped working? Anyway, anything you can describe it will allow me to troubleshoot as I have a DUO and it’s been smooth for me for the entire time. :slight_smile:
plugin stopped working entirely-- my board is kind of a mess right now, full of random utility/CV plugins from older iterations, and lots of beta/cookbook plugins… I really need to try it on a cleaner setup. Hopefully will have time this weekend.
@oeSmash Ok, I ran some extensive testing and so far nothing pointing to the plugin.
I have bumped the version to incorporate a couple of small performance changes. (version 1.0.15)
  • Animation switch: new in Performance, in the settings, on by default. Off, there’s no glow and the plugin stops sending face data altogether. Tested: the sound is identical either way.
  • Fewer messages: the face data now goes out at most about 30 times a second. It used to change on every audio block.
  • Lighter redraws: a readout only redraws when its own knob moves. It used to redraw all eight.
Cloudbuilder install:
It sounds amasing! I Can’t wait to get back to home a try it out!
Please add latch and momentary option - it will be more than perfect then :smiley:
@Lukasz Not sure what you mean, as it can be set to latch already? (When assigning the footswitch it defaults to momentary, but allows latch and momentary off as well)
There’s a clear button as well that can be assigned in case you use hold as a latching switch? Cheers
It would be handy to be able set momentary or latch as a button on DuoX so I couls switch from one option to the second without using editor, just with the hardware.
@Lukasz not sure if that is possible, but happy to have a look.
@Lukasz Midi and CV already would allow you to do this. I’ll see if i can add the feature to the next version under performance settings. If anything it’s a bit confusing as you would assign the “hold” footswitch to momentary, but then choose between momentary or latching behavior under performance settings. :wink:
@Lukasz Use the “multi button to CV” plugin and set it up like this:
Then in Temporal Rift, set the latching CV output on the “hold” switch
And set the momentary CV output on the “damper” control (make sure it’s 0 to +10v)
That will give you:
-single press = latch, single press again = unlatch
-long press = momentary on, release after long press = momentary off
That would actually be an even better setup imho. Quick press will latch it, holding the press automatically becomes momentary.
Cool plugin. It would be great to integrate an auto‑trigger function (like in EHX Superego) so you don’t have to keep pressing the footswitch.
@V_P yep sounds cool,I’ll look into it. :+1:
Version 1.0.17
  • Auto Latching option in settings
  • When Auto Latching, Hold prevents any notes from retriggering
  • Sensitivity and tremelo retrigger behaviour are settings only for now (no GUI)
  • in-built PDF manual as it’s getting a bit complicated (“see documentation”)
Cloudbuilder:
@V_P Haven’t tried it myself yet, but sounded like a good idea, so there you go. :slight_smile:
WOW! just WOW! Thank you for the quick response! It’s amazing how fast and cool it turned out. A very powerful and versatile plugin for those who like to hang their chords in the air. My old pedalboards with CV‑based auto‑freezing are going to the archive))
In any case, many, many happy evenings with your plugin are already guaranteed for everyone who installs it, but if I may offer a couple more suggestions, I would ask:
  • It would be a nice option to be able to limit the length of frozen notes in some cases — for example, so that, in the absence of new sounds, a frozen chord doesn’t sound forever but fades out smoothly after a set time (great for the end of a performance).
  • And the boldest idea — is it possible to implement a Glide function between the captured chords (like in my favourite SuperEgo), where the chords aren’t just blended with a fade but flow and transform into each other (Glissando? Portamento?)
Please understand me correctly — these requests of mine are rather hypothetical; the plugin is already excellent, incredibly functional, and beyond praise.
Thank you so much for your work!
