Hi, I’m working through the process of trying to include a plugin in mod-plugin-builder. I’ve submitted a pull request for the .mk file (which might need tweaking?). Am I on the right track?
On the functionality of the plugin i have my questions. I’m not sure if it should not be some sort of system feature (maybe as a tool) for something like a “Testing/Pedalboard creation” mode
The pd abstraction is in the repo and is very simple, if you want to check the functionality. I’m open to any questions or improvements - once all the Mod gui and build stuff is sorted out, the actual dsp is by far the least part of the work!
I would have liked something like this as a system feature (maybe as part of the output limiter, with a way to perceptually set the loudest output to allow?).
Anyone who has a rummage through the beta plugins risks rapid unscheduled disassembly of their ability to hear. After some frightening audio blurts I had to find a solution. This does the job, so far, but a built-in test mode would be excellent.
