New AIDA-X colab trainer
For those who like me are still interested in Aida-X, i started working on a trainer that could solve the recurring issues of the original trainer (mostly related to the use of deprecated tools versions). There is still A LOT of work to do on the notebook side to make it as user friendly as a Colab notebook can be. I had pretty good results with my first few tests. I would appreciated if some users could test it and give some feedback.
oh that’s great news, I can give it a spin after the weekend!
One issue with the trainer I found is when I try to export the model, I get an error message because the sample rate was not defined at the export stage. I had to use Gemini to fix that so that I could export models then. Once Gemini fixed it, I managed to export models successfully.
Maybe you can apply a fix to the page so users wouldn’t have to rely on Gemini to get results.
Other than that, It works nicely at the moment unlike the old Colab page.
Thank you for reporting this bug. SAMPLERATE is now defined at cell 2. It should now work fine when the “evaluation” cell is skipped.
