Need help - MOD Dwarf not seen by PC
Hi Everybody.
I need help because after some time I’ll be using my Dwarf again this evening and I have an issue.
I’m connecting the Dwarf to my Ubuntu Studio 25.04 laptop via USB, like I already did a lot of times, to access the web interface but it seems it’s just not recognized.
No error, no message, but also no entry on the network connections when I plug and unplug.
What could it be?
UPDATE: I’m trying to connect the Dwarf to various other laptops, including Windows, and changing USB cable. It just seems that it’s not seen by the PC OS
UPDATE2: Of course I set the USB connection mode to win+midi before trying to connect to a Windows PC
I thought I saw this behavior on Ubuntu Studio 25.04 as well, but after I unplugged and plugged the USB cable on the Dwarf end, it worked as expected (firefox connected). You might try fussing about with udev rules, but that seems extreme.
Start up Ubuntu, then plug it in. Does it show up in the terminal with lsusb? If so, can you ping 192.168.51.1 it?
I tried to ping the IP as you said, but it just gives request timed out
Welcome! I believe we will need more specific information about your issue before we can help. You may want to look at the troubleshooting page of the wiki at Troubleshooting - MOD Wiki as a launching point. If you write a detailed post including information about your MOD device, computer OS, browser, etc., we will be more able to help you.
