A while ago I tested updated and optimized NeuralAudio on a Dwarf, but it is still not enough to run standard models.
I dont think the PiPedal project really has more optimized general version, it is just that the Pi has more CPU power than the Dwarf, and thus can NAM related stuff better.
The use of PGO (profile-guided optimizations) is something the ToobAmp author said improves CPU usage and I still need to try, but it’s unrelated to any project though and just a generic optimization technique that can be applied to any plugin.
yeah - looks like the Pi is indeed just more powerful
“A Pi has much more CPU horsepower than a MOD Dwarf. 2.4Ghz A76s x4, vs 1.3GHz A35s x4. Not just the clock speed; there’s also a huge difference in performance between an A76 and an A35.”
To be clear you are saying “Raspberry Pi 5”, because there are enormous differences between the different “Pis”.
(and it doesn’t make much sense in plainly comparing with “Raspberry Pi”)
The Dwarf is somewhat comparable to a Pi 3B+ in that regard.
