205 / 5.000
I tried NAM for my first time and basically I can’t use it because the CPU reaches 100% and the sound is distorted, has this happened to anyone? Is there anything I can do to make it work well? Thank you
205 / 5.000
Are you using nano models?
Heavier ones will not work because the CPU gets overloaded.
Tonehunt provides a filter: nano-mdl NAM Profiles & IR's · TONE3000
Hi Gianfranco,
I’m using DWARF, and I get the files from the site recommended on the directions: tonehunt.org and the file is .nam and the file is DV Mark Jazz 12.nam
I would also like to point out that on that site when I search for files for AIDA I actually find .nams that are not for AIDA.
What @gianfranco means is that you should use nano-mdl models on the Dwarf.
On tonehunt, go to the “Technical” tab, select “nano-mdl” from the list and press “Apply Filters”.
Then you get a selection from nano models which properly work on the Dwarf because they are much lighter in CPU consumption then standard models.
A bit bellow the Platform tab there is a tab called “Technical”, it’s the last tab. Select that and select “nano-mdl” from the list. Then press “Apply Filters”
Thank you
