David Robillard
Fomp is an LV2 port of the MCP, VCO, FIL, and WAH plugins by Fons Adriaensen. A fairly simple design which does not even pretend to come close the 'real thing'. It uses a very crude approximation of the non-linear resistor in the first filter section only. Retained in this distribution because it's a cheap (in terms of CPU usage) general purpose 24 dB/oct lowpass filter that could be useful.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2Ryb2JpbGxhLm5ldC9wbHVnaW5zL2ZvbXAvbXZjbHBmMQ==
