this was actually the other way around. So by default, it was on and not off. In that case when I do the next step…
…it actually turns the “Panner” off". With the “Panner” off, everything is off except the CV clock and the CV Attenuverter Booster.
When I do these steps, indeed the pedalboard is loaded with all the states off, but the CV working on the MOD Volume.
I then replaced the MOD Volumes plugin with another random plugin and did exactly the same assignments. The same happens, so indeed there’s a bug here (probably from the CV plugins…and probably the Random CV Generator that always loads with a default on even if the UI shows the opposite).
I tested on the latest 1.12. I will report it.
Thanks @Rom
