Description
After powering up the MOD, the saved inital value of the MOD-True-Bypass pedal isn’t restored correctly.
How to reproduce
- Create a pedalboard with the MOD-TrueBypass-Pedal, activate it for True-Bypass, save the settings.
- Power Off the MOD
- Power On the MOD
- Check True Bypass State, and Pedal State.
Expected/suggested solution
Correct Power ON Steps if Bypass-Pedal is active.
Additional information
Initialization only fails after powering the MOD ON. When it gets loaded from the memory everything works fine.
- release: 1.6.0.596
- controller: bf9013f
