Hi, on the WIKI for “How To Use Docker Toolbox With MPB” I read
NOTE: The current pre-compiled image can only compile plugins for the Duo.
But I also note that the info is 3 years old, so I am just wondering if there is a precompiled image for the Duo X by now? Or should I still go the “advanced, long” route instead?
I am on a Mac but I used an Ubuntu 22 VM, it was a bit of a pain to set up but you can actually have it up and running like you are using a mod device with the web interface.
I have it all setup in VSCode using the Makefile extension and you can then use the debugger from inside VSCode.
