Mod + other pedals
Hi
not sure if this has been discussed elsewhere (if so let me know) but I’m wondering what everyone is doing with regard to using Mod Duo/X/dwarf with other pedals that they, very likely, already have.
If I want to use a reverb pedal that I already have then I can use my DuoX as normal but not add a reverb to the pedalboard…but what if I want to use an external chorus and a reverb from the DuoX…
Specifically, where does your Mod device sit in your chain(s)?
thanks
If your signal chain is mono, you can use the Input/Output #2 pair on the MOD Device as an effect send/return.
This will allow you to put your external effects anywhere in your MOD pedalboard chain.
right, that does seem to be the most flexible
