MOD OS 1.14 RC1 (build 3333)
Hi everyone,
this is the first release candidate of MOD OS 1.14 for Duo, Duo X and Dwarf, codename “Evelyn, a Modified Dog”.
It is a test build: install it if you are comfortable reinstalling a previous version by hand, and please report anything odd in this topic. The new “Report a problem” button in the Web UI brings you here with your device details already filled in.
Download
Device File SHA-256
Dwarf moddwarf-v1.14.0.3333.tar 40dfd1791ef62caeb6a1b25fcf43d90a9e3cf9e7bb6dfafbdd1fd2381eb4dbc1
Duo X modduox-v1.14.0.3333.tar 91ddbd74426fba9d588ef129b1c30ffc16836f8b3182aa39a3a46efab8192f9e
Duo modduo-v1.14.0.3333.tar bdbad334c2ff8a1707f7038fefe6af0a3f78e18ae24c064dddcaebd7643aa366
Install
  1. On the device: Settings → System Upgrade. The device shows up on your computer as a USB drive.
  2. Copy the .tar for your device onto that drive and follow the prompt on the device.
  3. It reboots, installs (about five minutes) and comes back on 1.14. Your pedalboards and
    files stay in place.
To go back, install the 1.13.5 file the same way. You can download it from the Releases page.
What’s new in 1.14
  • Tone3000 inside your device. The NAM loader, the cabinet simulator and the IR loader
    have a “Browse tones” entry: log in to Tone3000, pick a capture or an IR, and it downloads
    straight into the plugin. Brought to you by MOD Audio, made possible by the
    Starless team. :heart:
  • Grouped plugin controls. Plugins that declare port groups now show their controls
    grouped and colour-coded in the settings view, created by the Starless team :heart: with support from MOD.
  • Easy Spin programs. The File Manager has an “Easy Spin Programs” folder and the
    plugin’s .json programs are recognised. EasySpin is a very exciting upcoming plugin and project by @mark_melvin
  • Drop and replace. Drag a plugin from the sidebar onto one on the board to swap it,
    keeping the connections.
  • Snapshots are always saved, their screenshots refreshed, with a save indicator.
  • Control Chain devices behave exactly as on 1.13.5. Persistent assignments across
    unplug/replug are ready on the development branch and will come in a later release,
    once the new update flow has settled.
  • MIDI program-change pedalboard switching works again after the last Web UI session closes.
  • A Stable / Testing update-channel setting inside Settings (for now a preference only; the update server side comes with a later build).
  • Report a problem button: opens this topic with your system details ready to paste.
  • Under the hood: newer audio engine (jack2, mod-host), Control Chain master, MIDI merger,
    updated resampling and ALSA libraries, plugin frameworks (DPF, JUCE, Carla), plus a long
    list of fixes (silent failures in snapshots, plugin install and file transfers; pedalboard
    screenshots; a crash at startup in the Python bindings; mixer profile per sound card).
Known issues
  • Once, deleting the NAM plugin right after a Tone3000 download crashed the audio server
    (it recovers on reboot). We could not reproduce it - if it happens to you, tell us exactly
    what was loaded.
  • On the Duo, the built-in sha256sum command gives wrong results; verify downloads on your
    computer instead.
How to report
Web UI → “Report a problem” → copy the text → paste it here with what you did, what you
expected and what happened.
Thanks for testing!
Great. :raising_hands:
Where can I find modduox-v1.14.0.3333.tar?
Edit: Done. Now online: 1.14 - Google Drive
announcement on the way. you just saw because you’re a beta tester.
thanks, @gianfranco - great to see an update!
i’ve got a show in a couple of weeks, so might be tentative about testing for now, but is it looking stable so far in your testing (especially on DuoX)?
and one question:
is this likely to yield any change in performance load before xruns?
cheers… hope you’re well!
Whoa! I know what I’m doing this weekend! :slight_smile:
Thank you, sounds like a fine update for my DUO,
but until there is an On-Device-Editor for the Dwarf, Starless reigns supreme! :grin:
getting there :slight_smile:
Congratulations!
Some interesting new features.
This community can start buzzing!
