Mod Duo X Product page says TRS audio I/O?
So the specs say;
Audio:
Independent audio I/O (stereo or dual mono) with a pre-amp per channel and a master volume control
Headphone out with dedicated volume control
Configurable TRS input – 2 x CV / Expression pedal ??
Configurable TRS output – 2 x CV / Headphone ??
Cirrus Logic low noise audio AD/DA converter
Relay-based True-Bypass
I’m not sure if it’s a typo but aren’t the two inputs regular mono TS jacks?
That’s the case for my Mod Duo at least, right?
It would be cool though!
We could use dual TRS to make an external stereo effects loop, for instance :open_mouth:
it refers to expression input which can be switched to accept CV - in that case using trs to 2 x ts splitter you can send 2 x cv to DuoX. It is this same with headphone out, it can be used to connect headphones or output two CV.
Yup dumb mistake from me…
Would still be freaking cool if the audio ins where both stereo right :smiley:
yes, I agree!
